Hows this happens with only 36k miles?
  • Hows this happens with only 36k miles?
    motor was put in 4 months ago..all new gaskets and a new timing chain..so i have no idea..going to pull the timing cover later this week and see if anything strange is going in there..cam is fine
    Rear Head
    Front Head
    All 6 pistons have this little knick (wasnt there 4 months ago)
    Cyl 2 exhaust pushrod
    Best 1/4mile ET - 12.9
    Best 1/4mile MPH - 111
    1997 Ford Ranger Splash
    Daily Driver
    How much lift on the cam? Cause that little knick sure looks like a valve is hitting.
    Far right exh. valve in the 2nd pic looks like it has a knick on the outside edge as well.
      wierd, looks like the timing chain jumped or somthing
      also looks very oily for 36k
      did it just all the sudden go bad and you couldnt start it again?
        Am I seeing things, or are all the exhaust valves bent?
          I have knicks like thoes on my pistons. Happened when the pistons went up, and the valves went down.
          I had to replace both heads, and reset the timing.
          Taylor
          1998 Lincoln Mark VIII
            everything engine wise is stock other then LS6 valve springs..they may look oilly from the way i had them sitting and from removing them and since it hasnt ran in a month..i havent cleaned them since i installed the engine..all the exhaust valves may be bent..i know atleast 3 are noticeable..not to worried about the heads..i have new ones sitting here waiting already
            car was running fine..left a light being easy and thats when it went..no power at all..ran but not willingly and sounded like shit for the few seconds i could get it to run..now i know why..lol..im gonna check the chain later this week and see what i find
            Daily Driver
              As I replied on the bstuff board if you find that the chain jumped a tooth, my jaw will drop... I'm unsure on how something this tight could jump a tooth...
              I'll share this with this crowd, but in my opinion I think he broke the cam timing tooth off...
              Is that possible if the cam bolt isnt tight enough?
              this is the tooth I mean. better known as a dowel/pin I guess...
                I suspect that center guide to be broken allowing massive chain sloppage which could allow timing to jump a tooth or two.
                  if i rememeber right i torqued the bolt to what it says here on the site..also that guide wasnt broken 4 months but who knows now
                  Daily Driver
                    if the chain stretched it's pretty easy to jump a tooth or 2.. It's possible that the crank key broke... seen that a few times.
                    If that pin broke off on the cam the car wouldn't run at all.. even at 100+ lbs of torque on the cam bolt the sprocket would still rotate pretty easy w/o the pin.
                    Scary stuff.. in for more carnage pics...
                      Carnage FTW!!!
                      HAHA just kidding.
                        subscribing
                        Brian
                        3400 SFI V6, 4T60e
                          lol..ill have more picture this weekend when i have time agian to work on the car..i dont have the time to do it between work and school during the week right now..damn finals
                          Daily Driver
                            email notifications... on.
                              Got the cover off need a new cam..the little pin broke off..ill get pics when i get my camera back tomorrow
                              Daily Driver
