"Most people say that Curiousity killed the cat. I personally say that curiousity never killed anything except maybe a couple of hours!"
I started the OBD2 swap in my 1988 Cutlass Supreme. I am basically putting it to completely stock 1996 3100SFI (Vin J LG 8 )/4T60-E. I have a donor car (the pink car..... May it rest in pieces), so the wiring is not my issue.
I was going through some of the wiring to see what the main differences were, and I found some things that I am EXTREMLY curious about.
First of all, the OIL PRESSURE SENSOR only has one wire. Now my 1988 Cutlass Supreme was originally like that, but when I updated it, and then later when I did the original 3100MPFI, I had to put in the 3 wire sensor. The combined oil pressure sender, and fuel pump relay thingie.
The 1996 wiring only has the 1 wire. Not 3. What is up with that? I will get a pic of it tomorrow.
Also, it has that DOUBLE CANISTER PURGE thing. I did get a pic of it. What is it for, and why?
Lastly, the pink car seemed to be prewired for the VARIABLE ASSIST power steering. There was a red connector on the back of the engine near the EVAP stuff, but it was not plugged in. The terminals have turned green, and shit.
Is there a way to put that in without adding the ABS? Not that I am going to attempt it. Adding ABS to a 1988 car is close to impossible. Besides, the rear hubs were bad in the pink car and I can't afford new ones at this time.
I just know that it is controlled by the EBCM (I don't have the proper EBCM anyways. The pink car did not have the EVO, but my green 1995 Cutlass Surpeme does.
That is about it for now.
