If someone has a table that shows the Idle RPM compared to the Coolant temperature on a stock 2.8/3.1 5spd (manual only!) I'd appreciate it... I need it to set my idle on the OBDII ECM for my 3400 5spd...
Need Idle RPM vs Coolant Temperature Tables
Desired Idle Speed Vs. Coolant Temp (In Drive)
Deg. C RPM
(null)
152 900.00
140 900.00
128 875.00
116 862.50
104 850.00
92 850.00
80 875.00
68 900.00
56 1000.00
44 1150.00
32 1250.00
20 1250.00
8 1300.00
-4 1350.00
-16 1400.00
-28 1600.00
-40 1700.00
Desired Idle Speed Vs. Coolant Temp (In P/N)
Deg. C RPM
(null)
152 900.00
140 900.00
128 875.00
116 862.50
104 850.00
92 850.00
80 875.00
68 900.00
56 1000.00
44 1150.00
32 1250.00
20 1250.00
8 1300.00
-4 1350.00
-16 1400.00
-28 1600.00
-40 1700.00
that's from the $A1 3.1 5 speed code. Both are the same, i'd assume it reads from both...Last edited by Superdave; 04-19-2007, 11:44 AM.
Yep, they're in °COriginally posted by heavywoody View PostGreat! Thank you Dave!
One question: I'm assuming those temperature readings are in Celsius?
No problem, your lucky i had Tunerpro open at work.. haha
