I recently picked up a '03 3400 to put in a '96 Grand Prix that had a 3100. What would it take to make the 3400 injectors work in the older vehicle? I do have the injector harness for both engines.
3100/3400 injectors
You'd need to find a way to tune the computer to the higher flow rate. DHP/HP tuners could do this but you'd be paying a LOT just to get different injectors working. The 3100's #17 injectors should run a 3400 fine unless you plan on going past 200HP.1995 Grand Am SE
Originally posted by 4-speed View PostI recently picked up a '03 3400 to put in a '96 Grand Prix that had a 3100. What would it take to make the 3400 injectors work in the older vehicle? I do have the injector harness for both engines.
I know this swap is common for you guys, but I just got this thing running this morning and I can't believe how simple it was and I have to smile when I put the pedal down.
The 3100 injectors work just fine.
