timing cover ?
  • timing cover ?
    I was wondering if any one knows if a RWD front cover will fit a 3400 block, i think there is a differnce but i can't find any info on it here
    It will bolt on but there is a small hole in the cover that has to be plugged. I have a pic of a RWD cover on a 3100 posted in another thread.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
      sweet will the steel oil pan bolt up too, it would be much easier to modify that than cast one
        Hopefully someone else can answer that for you as I really don't know for sure.
        I do know that the cast pan is supposed to add some strength to the bottom end of the engine.
        '79 MGB - LZ9 - T5
          No it will not bolt up.
            darn oh well, well at least the timing cover will work
