UPDATE: '93-'95 3.4 RWD Specs (Please Add To Pushrod Specs)
  • UPDATE: '93-'95 3.4 RWD Specs (Please Add To Pushrod Specs)
    Most of the following info was found on www.firebirdv6.com. I've added some stuff that I know from the 3.4L that I purchased from Deathmobile:
    Ref: http://engine.firebirdv6.com/
    Desc: L32 3.4L (204ci) 60° V6, RWD
    HP: 160@4500 (60dv6.com lists 160@4900)*
    TQ: 200@3500 (60dv6.com lists 200@3600)*
    Block: Cast Iron
    Heads: Cast Iron
    Intake: Aluminum (wishbone configuration)
    Exhaust Manifolds: Cast Iron
    Bore: 3.62" (92mm)
    Stroke: 3.31" (84mm)
    Compression: 9.0:1
    Intake Valve: 1.72"
    Exhaust Valve: 1.43"
    TB size: 50mm
    Firing Order: 1-2-3-4-5-6
    FI System: SFI
    Stock Injectors: 17lb (AC Delco 217-301)
    Stock Cam Specs:
    Duration: 195°/201°
    Lift: .263"/.273"
    Lobe Sep Ang: 109°
    Intake Center: 111.5°
    Rocker Ratio: 1.5
    Gross Lift: .394"/.409"
    I remember someone was going to measure the combustion chamber of the heads on this puppy - anyone got around to it? I'll do so if not, but it'll probably be a month or so before I can get it done.
    * I have found other sites that list the RPMs at which the HP/TQ peaks occur as being 4600/3600. So there's obviously some disagreement across the web about these. Anyone got RELIABLE printed specs on these? But at least the peak amounts are known: 160HP/200LB-FT.
    SCREECH
    1976 Olds Cutlass Supreme Brougham, 468ci BBC
    1990 Chev Celebrity Eurosport Wagon - undergoing 3.4/5-speed conversion
    1987 Chev Celebrity Eurosport Wagon - beater
    I got the Camaro specs on a cam specs on a cam card
