^ most likly ur right
roush 3500?
Originally posted by SappySE107 View PostWhat about the heads are different on the 3500 that isn't VVT? Every head I have had so far has been identical.
When I called in an effort to find an extra set of heads I was prompted for the casting number because there were two listed. Apparently a different design is used possibly based on whether or not the engine is designated for Flex fuel use in which all 3500s are not, hence the possibility the specially treated valves for corrosion resistance GM mentioned on their site is used in that particular cylinder head as well.
I also recall mention of a characteristic feature inside the port of the 3500 head that was also seen in the picture and that was absent from the cylinder heads I had also. Both can't perform the same with those differences and I suspect the latest design is the best. I don't recall the 05 G6 being flex fuel rated.
Originally posted by SappySE107 View PostWhat casting number was it then? I need to see pictures of this.
I have several pics of 3500 head casting #'s from the many sets of heads that I have had in the past year. I also have a spare set in the garage at the moment. These range from 04-06 heads, so I will see if anything is different between what I have.2000 Grand Am GT
2011 Chevy Impala
Originally posted by 93ztwo4 View Postwell i will be taking my heads off to get them ported so i will take some picture then. but it wont be for like a month. so if it turns out that this is a flex fuel engine what would i need todo to run flex fuel?
GM uses some kind of photometry sensor that senses the level of alcohol in the fuel and the computer makes the necessary adjustments to take advantage of it.Last edited by Guest; 01-25-2007, 05:03 PM.
Here is the casting number from the heads that I sold that were different;
12578523. I took that off of a picture that I have of the engine. Unfortunately I do not have a good number shot of the heads on my 05 engine for comparison.
If you look at the combustion chamber on the cylinder head on the first page of the 3500 vs. previous engines thread you will see what I'm talking about. There is no way you can not notice that "unibrow" ridge next to the valves and the heads I sold did not have it.
I checked GM parts direct and they show a cutoff of 04-05 on the heads and then 05 or 06 up. The price is the same but if the heads were all the same the year would be from 04 to the present. The 3900 heads are different all together.
From all the 5 sets of 3500 heads that I have had I keep coming up with the same casting #12578523. The head pictured in the thread "3500 Differences from Previous 3x00s" was one of my heads, just extremely dirty at the time.
What other casting # are you saying there is?2000 Grand Am GT
2011 Chevy Impala
mine are casting #12578523 as well...
