need pics of accessory mounts
  • need pics of accessory mounts
    hey anyone got any pics of how the accesorys bolt up on a 3100/3400
    i built an 3.1(3.3L)/3xxx hybrid for my camaro but my tensioner,alt,and other things wont bolt to the heads since the bolt spacing is diff.i could just make adapter plates but if i can get pics of a 3100 motor with everyuthing bolted on it i may just be able to adapt it to a rwd setup
    thnx in advance
    You'll be worlds ahead to use the RWD belt set-up, especially due to where the power steering pump goes, that will be right in the way of the thermostat housing and TB, when the intake is turned around for the RWD application.
    Make some adaptors and be done with it, I've gone through all of these ideas already, that's why I keep tellong you how to do this, but you seem to not want to listen.
      yeah i know lol.i just like to see how many diff options i have for doing something though.that and i might be eliminating the power steering..if i manage to do that im just gonna adapt a v belt setup and simplify things
      edit
      btw the thermo housing is no longer on my intake,i ended up using a remote thermostat housing plumbed in with some -an lines.
