Lifter bore spacing?
  • Lifter bore spacing?
    i was wondering if anyone knows the lifter bore spacing on a 3.1l MPFI? i want to convert to mechanical roller lifters but need the spacing measurement. if anyone knows, i would appreciate any info.
    If its the same as the 3500, i can try and get you a measurement. I don't see why they wouldn't be the same.
      Crane already makes Lifters with the anti rotation bars. Just call them up.
        thats what i want, crane solid rollers but when i called summit they told me that its different then a small block's and that they dont have any for my motor (figures). i guess i could call crane direct which is what i should have done from the beginning.
          According to Curtis, Crane does not make or sell them. But Crower should be able to fix you up.
            i went to crowers web site and they have ones for a 2.8L it doesnt say if they are hydraulic or solid. im assuming they are solid. part number 66208-12. these should work?
              Wow... are they really worth $350 to you??
                if they fit the engine and work, very much worth it. i drag race it regularly and want the engine to run good all the time. ive already destroyed my flat-tappet lifters in only 7500 miles.
                  Lifter bore spacing is 24.5mm on the 3100 & the 3900 and I assume it would be the same on all other 60V6s.
                  MinusOne - 3100 - 4T60E
                  '79 MGB - LZ9 - T5
                  http://www.tcemotorsports.com
                    Just to chime in, Yes the spacing on the SBC is larger. I tried to fit my Comp roller lifters from the T/A in one of my 3400's and it was way off...
                    I don't see why you couldn't have new anti-rotation bars made for it tho. The lifters are the same size. This might be something to bring up to Comp or Crane...
                      i called crower yesterday and they had a set in stock so i just ordered them. now i need a cam.
