I changed my rockers on my 3.1 to the rockers off of a 3100. it ran like crap so i changed them back, now it still runs like crap. rough idle no acceleration, sounds like its running on five cylinders but all plugs are firing. I really need help if anyone knows what the problem is or has any ideas!
Engine running weird need help big time!
1996 Beretta
3100 SFI TURBO
T28 60 Trim Turbo at 9psi, Stage 1 turbo cam mms, lifter upgrade springs mms, P&P heads, ls6 Valve Springs, Ported exhaust manifolds, Hyperuetectic pistons SP, 3.29 trani, MSD 8.5 wires, open exhaust, Pulstar plugs, 3400 intake manifolds, ported TB, 36 lb/hr injectors, RCI Fuel cell, Walbro 255 pump, A/C Bypass, and much more.
13.1 @ 103 mph best in the 1/4 mileTags: None
Did you put the wires in the right order?-Brad-
yes i checked the wiring order and it is all correct. I think i bent a valve but im not sure. any other suggestions. i am going to do a compression test later.
1996 Beretta
3100 SFI TURBO
Kinda off topic, but why would wires make a difference? They shouldn't have come off anyways. Gotta go with a bent valve, or some such thing.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
I checked the compression in cylinder 2 and it had about 10 psi. I bent a valve but im hoping its from the rocker slipping off not the piston. Is it really hard to change a head? its the front head.Last edited by Jbrogan; 10-23-2006, 08:37 AM.
1996 Beretta
3100 SFI TURBO
