what rwd tranny if any will bolt up to the turbo 3.1 ltr ??????
FWD 2 RWD
FWD 2 RWD
91 cavaliver z24 5 spd,
89&90 TGP auto
90 olds toronado trofeo auto,
86 GLX RX7 5 spd,
85 nissan 300zx 5spd,
84 dodge ram,
http://www.kustomdreamzcc.zoomshare.com/Tags: None
Also the 2.2L trannies (NV 1500) which is a little weak if your going for high power.
2.5L iron duke (from S-10) will also bolt up. It is the same T5 used behind the 2.8L. The only thing with the Camaro trans is that it is rotated a few degrese to the drivers side. But it may be desierable in some cases. Also the shifter is about 6" further back than one found in an S-10.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
welll heres the whole story .. I have an 85 nissan 300zx that after 249XXX miles the motor died.. It has a 5 speed already .. well I have an extra 3.1 ltr turbo motor sittin in the corner.. I thought it would bee fun to swap in the 3.1 and a rwd tranny .... I think in the rwd form I could really see what this motor could do.. I love my tgps but the fwd traction thing is hard to get over and when it is the tranny or some othe part goes ......91 cavaliver z24 5 spd,
89&90 TGP auto
86 GLX RX7 5 spd,
84 dodge ram,
yup custom headers and since I have a spare turbo too I might try twin t25 turbos.....Maybe91 cavaliver z24 5 spd,
89&90 TGP auto
86 GLX RX7 5 spd,
84 dodge ram,
i myself would put a nissan motor in, like a vg30dett or even an rb25 or rb26. it would be kinda cool to put a 3.1l turbo in a rwd, but when you think off all the work involved, id much rather put a 3.4l tdc and twin turbo it. but realy in the end, even if you get 350hp from it, a newer 300zx with a couple bolt ons would walk the thing.
yah the point of the thing would be that its all stuff thats lying around my shop and would make a fun car to play with..91 cavaliver z24 5 spd,
89&90 TGP auto
86 GLX RX7 5 spd,
84 dodge ram,
would be fun to do if you have the equiptment to build custom mounts, exaust, ect. probly will end up costing you more money in all the parts to put the 3.1l turbo into it than to go find another stock nissan motor. heck, if you sold the 3.1l turbo motor, it would likley cover the cost of the new motor.
I have tried to sell the spare motor and tranny i have .. No one wants to pay anything for it ...
Anyway a vg30dett is tooo wide It can be done but with alot of work and even more money... and the rbs arent a dime a dozzen but they can be done as well..91 cavaliver z24 5 spd,
89&90 TGP auto
86 GLX RX7 5 spd,
84 dodge ram,
What tranny do you have. Is it a T5? Might be some helpful info here:
A while ago I posted pix and discussion of a simple and inexpensive way to set up the RWD/T5 combinations without using the hydraulic throw out bearing. It uses the stock GM hydraulic parts and can be done with the s10 or camaro bellhousings. The camaro bellhousing has to be modified a little, b
GregLast edited by Greg55_99; 08-18-2006, 09:15 AM.
well Greg55_99 my origanl question was what trannys would fit on the 3.1 in rwd form...91 cavaliver z24 5 spd,
89&90 TGP auto
86 GLX RX7 5 spd,
84 dodge ram,
Originally posted by TooManyCarswell Greg55_99 my origanl question was what trannys would fit on the 3.1 in rwd form...
The 3.1 has it's starter on the drivers side. That's why you'll need the two pocket bell.
If you find a T5 from a V8 Mustang (not a V6 or 4), you can use the bellhousing from a 94-95 2.2L S10 pickup. It also has a pocket on the drivers side. That's it on the left below.
Hope this is helpful
Greg
thanks thats awsome91 cavaliver z24 5 spd,
89&90 TGP auto
86 GLX RX7 5 spd,
84 dodge ram,
