Transmission Swap 96 Lumina 3100 4T60E to 94 Cutlass
  • Transmission Swap 96 Lumina 3100 4T60E to 94 Cutlass
    I am installing a 96 3100 and 4T60E in my 94 Cutlass but I noticed a difference in the connector for the trans. Can I just use the old one from my 94 or is it connected internally?
    Thanks,
    Mike
    use your old connectors / also make sure you use your old torque converter. Just did a similar swap 96 GP to 94 GA...
    2004 Pontiac GTP 3.8 SC
    1997 Pontiac GTP 3.8 SC
    1996 Pontiac GTP 3.4 DOHC
    1990 Pontiac TSTE (x2) 3.1 Turbo
    1990 Pontiac TGP 5Speed
