92 Regal / LeSabre 3800 4t60 4t60E swap
  • 92 Regal / LeSabre 3800 4t60 4t60E swap
    Hello. I have a 92 Regal with a Bad 3800 / 4t60. I Purchased an engine transmission combo from a 92 LeSabre 3800 with an attached factory rebuilt 4t60E. From what I can tell, I'll need the ecm and wiring harness from the LeSabre to get the 4t60e to work correctly. I'll also need the axels from the Lesabre as the 4t60e tranny is a bit wider. My question is what mounts do I use? The tranny mounts from each car are different and I'm not sure wich if any I should use. Do I need to modify them in some way? Am I on the right track so far? If anyone else has done this a step by step guide would be fantastic or any helpful hints or tips would also be of great help. Mag4200@cvzoom.net
