right now i am having major traction problems in 1st and 2nd gear. i'm using a Getrag 282 from an '89 Grand Prix. 1st gear is so damn steep it makes the car really hard to launch. the tires go up in smoke once i reach ~10psi in 2nd gear as well.
is it possible to replace the current 3.77 1st gear and 2.19 2nd gear with 3.50 1st and 2.05 2nd gear from a V6 L-body 282? would there be a noticeable improvement in traction? i would like to rebuild the extra W-body 282 i have in my garage like this if possible:
1st - 3.50 (from L-body V6/282 for easier launching/traction)
2nd - 2.05 (from L-body V6/282 for more traction)
3rd - 1.38 (same)
4th - 1.03 (retain W-body V6/282 4th gear for acceleration)
5th - .72 (from L-body V6/282 for lower cruising RPM)
at first i thought i could simply drop an L-body V6/282 into my Cutlass but that is not possible since the case has no provision for the W-body trans mount and it uses an external slave cylinder which looks like it would interfere with the TGP turbo & lower IC pipe. another guy on the W-body forum said the W-body axles wouldn't fit the L-body 282 anyway. so it's looking like the only option would be to have the gears i want installed into my W-body 282 case when i have it rebuilt. i just want to know if this is possible and if it is would i notice a significant improvement in traction?
also....is there a numerically lower FDR i could use? or is 3.61 it?
thanks
3rd - 1.38 (same)
thanks
