Hey guys, this is my first post here. Im working on my sister-in-laws car and it started having tranny problems. The car has the 3100 in it with the 4t60e 4speed. The car has 120k on it and the filter on the tranny was replaced 20k ago. The tranny has never had any problems up until a few days ago. The 1-2 shift seems to be delayed and then hard. When giving it WOT it almost bangs into gear. With just a little throttle input its almost unnoticable. The car has no codes and aamco said all the electronics were good. They told her the problem was more then likely 'soft parts' and not the 'hard parts.' Im not sure if I believe them because Ive never had a good experience with them. Today i pulled the vac line off the modulator and there was no fluid in it(I read somewhere that could be a problem).
Basically where Im at is Ive never worked on an auto before. Ive done plenty of manual stuff of various makes but this will be my first auto. Is this a common problem with these 4t60e's? From what I read on your site its most likely a broken accumulator spring or possibly the valve body is messed up. Is this right? Im open to any help or suggestions I can get. Also Id like to know the best way to get the tranny out of the car if I need to. Everything is jam packed under the hood of this thing and im just wondering if I can drop some of the suspensions out and drop the tranny or what I can do. Sorry if thats a stupid question, I havent been under the car yet.
Any help I can get is greatly appreciated.
Thanks
matt
Thanks
matt
