Auto in 96 3100 corsica Drive train has 96,000 miles, seems to go into neutral when shifting from 1 to 2 on heavy acceleration. On slow acceleration it shifts fine. Also goes to neutral if it attempts to down shift to 2 from a higher gear. ie you try to accelerate through an intersection. Back off on the accelerator and it will shift into gear. Does not appear to slip once in gear, 3 and 4 are fine. Suprising me, I thought 4 would be a problem
Xmission was serviced recently. My code reader does not display xmission codes.
Any ideas out there????????
