1988 and up use the same flywheel till you get to the gen 3 motors i looked it up at work todya and gm even shows the same part # for the flywheel from 88 on front and rear wheel drive.
lightened flywheel
Originally posted by rx1911988 and up use the same flywheel till you get to the gen 3 motors i looked it up at work todya and gm even shows the same part # for the flywheel from 88 on front and rear wheel drive.
All '88+ Camaros used flywheel part# 14100559, ring gear part# 14033090. All '88+ S-10's use flywheel part# 14100556, ring gear part# 14033090. This is the exact same ring gear used for '85 2.8 S-10's, as well as the 2.0 and 2.5 S-10's. Advance Auto also lists the 148 tooth flywheels for '88+ RWD applications. Sounds to me like all RWD used the larger flywheel, regardless of year.
Marty'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
Originally posted by rx191i don't know about the s10's i ahven't researched those but all the f body's with 3.1-3.4 in them use the same flywheel as the fwd cars, even the ring gear is the same
If I had to guess, I'd say the RWD is probably using a thicker flywheel. So you might have problems with clutch engagement on a FWD flywheel. (Might, not sure) I know for a FWD 3800 on a 5spd, you have to take a RWD flywheel and machine it down to the FWD thickness.97 Cavalier RS
3400, Isuzu MK7
everywhere i have looked the part number is the same for thew flywheel for a RWD f body, camaro or firbird the fWD and RWD engines in these cars are the same fi the numbers match. i don't know about the trucks, but they mite have a heavyer flywheel for more touqe that could be why they are larger. i will research it a little more but numbers don't lie
Everywhere you look except for direct from GM, which is the numbers Marty posted. If anything is correct, I'd say it is GM.-Brad-
Originally posted by bszopiEverywhere you look except for direct from GM, which is the numbers Marty posted. If anything is correct, I'd say it is GM.
There is indeed a difrence in diameter between FWD and RWD, I had like 4 of each at one time all stacked on top of one another, that's how I discovered the differences.
I didn't think to check for thickness differences if any though, the diamerter was enough proof for me.
Oh just thought I'd mention the 3800 flywheel needs to be machined thinner, not to "match FWD thickness" but because the crank on the 3800 sticks farther out the back of the engine than the 660 or OHV I4s. Also the bolt pattern is different, so that needs to be redrilled.
from Greg's post in the Jeep forum.
"you'd need the thick (heavy) flywheel from a Camaro/Firebird. It places the clutch disk back far enough to completely engage the splines on the short W/G series input shaft. That's got to be at least 1 3/4" from the back of the block to the front face of the flywheel. The S10 flywheel is shorter (more narrow) and won't work."
The S10 flywheel I believe he's refering to is the FWD style flywheel, so that might answer your question.
I have heard of a difference in F-body Flywheels, buit that was ONLY in refence to the 3.4, mentioned in the 2.8-3.4 swap, for both S-10s and earlier F-bodies.
Originally posted by The_RavenOriginally posted by RebelGTfrom Greg's post in the Jeep forum.
are you saying Greg's info is wrong? I'm just trying to add more info to help figure this out, no need to be all dickish about it.
