Can we use an older 4t60e on a 01 Impala??
  • Can we use an older 4t60e on a 01 Impala??
    So my buddy's girlfriend has a 2001 Impala with a 3400. So it has the 4t60e. I know the older 4t60e's will bolt up but will older ones from older beretta and w-bodies will be a direct drop in with no changes? Any help would be appreciated, this is her only car and we need to get it back on the road ASAP.
    that car has the 4T65E, so no.
    Brian
    3400 SFI V6, 4T60e
      The 4t60e and 4t65e.,.. there's also a difference in the electronic controls too isnt there?
      My suggestion, try out www.car-part.com Or www.junkyarddog.com
      On junkyarddog i got a tranny, shipped for 300 bucks, with 90 days warranty. Not a bad deal. Still use it too.
      You'll be wanting a w-body transmission from 97 to, I believe 03. The 04+ tranny uses different connections once again. So they dont really swap in.
      97 Cavalier RS
      3400, Isuzu MK7
        See I thought it did originally too, but three different people told me it had a 4t60e......
          I know of the differences between 4t60e and 4t65e. I was told the car had a 4t60e and I was wondering if the old 4t60e's are the same. But yeah if it has a 4t65e she's just gonna have to spend the money......no shortcuts...
            yeah a lot of people think the 3100/3400's are not mated to the "oh so tough" 4T65E's since they're usually base models. The easiest way to check is to look for a metal vacuum line going from the engine's upper intake manifold down to a vacuum modulator (small canister) on the tranny. The 4T60(e) uses this setup, while the 4T65e does not.
            Brian
            3400 SFI V6, 4T60e
              But uhm. Since they didnt make the 4t60e in 2001, then it's a pretty good assumption that the car isnt using it. Could it be the 4t45e like the Grand am 3400 uses?
              97 Cavalier RS
              3400, Isuzu MK7
                all W-bodies recieved the 4t65 from 2000 on. The W-Bodies that had the L67 and now the 5.3 v8 get the 4t65-hd. The 4t60-e was discontinued for public sale in 1999. HOWEVER GM continuned fleet sales of the Chevy Lumina untill 2001, these cars were all base models equipped with leftover 3100s and 4t60-e transmissions.
                Any Impala 2000 or higher will have the t65.
                1995 Monte Carlo LS
                3400 SFI 60v6
                  good info
