if i did this swap id be trying to make one hell of a 2.8. mostly just to show what gm's tiny v6 can do. so a 9" is probly overkill, and its ford. its a project on paper so far, probly wont actually happen for quite a few years. most likely the 2.8 pushed to its limt N/A probly wont break a 7.5"gm, chances are it wil probly come down to weight between the possible donors. id really like to mix and match gm parts around to come as close as possible to the right width, and if i need to flare the fenders a little, no biggie. rather not have to have customs parts made, so if in the event i break something like an axel, i can just go pull one and not have to special order stuff.
i was hoping since the s-10 have a rwd offset wheel (wheras i dont the blazers do), that the axel would be narrow enough i could put a set of fwd offset wheels on it and come out to right width. i saw the dimensions are about 54" from face to face of the wheel mount, i remeber measuring the inside of my truck from inner quater pannels its right about 60" wide si i think the s10 axels with a fwd offset might be what the doctor ordered, but i wont actually know for like, 5 years... once again, thanks for all the helpfull info.
