Help trans problem - 4T60-E
  • Help trans problem - 4T60-E
    TRANS PROBLEM
    thing is the 1993 transmision currently has a problem that just started,
    not allways but every other week or so when i put it into drive it doesnt
    go into gear, then after a couple seconds it slams into gear.
    fluid is not low
    what could be the problem ?
    RE: A Couple Questions That Need Answers [ TC ]+[ 4T60 ] Rel
    93 GP should have the 4T60E tranny. Don't think I've seen one without it.
    The 88 tranny will be a 4T60, so basically no parts will easily swap over.
    Have you checked the fluid level of the tranny? I know when mine starts to get low (I REALLY need to fix my leak one of these days), it'd do exactly what you are describing.
      sounds like a sienoid problem
      my 92 gran prix did the same thing could be a sioniod if its electonic if not make be filter clogging or worn first gear clutches just a thought when clutch wear you can lose oil pressure to the clutch pack
