Is this an upgrade that makes a difference worth doing?I'm looking in to it but I don't know if it's all that.What are the parts and cost.can I order new insted of getting these peices from a donnor?
440t4 3.73 upgrade?
RE: 440t4 3.73 upgrade?
Ive heard it makes a better difference on the pushrods than the DOHC, but I have no experience with the DOHC in that config. Id say its worth doing if you don't mind a gas milage hit. The pushrods I am referring to hearing comments on are all gen 3 motors, not gen 2.Ben
Guess no one wants to help you. Let me find some of my old 440T4 manuals and see if I can find any information for you. I think really the only differences between the 440T4 and 4T60E, as far as changing the ratios, might be the diff ratio and the chain/sprocket setups. I'd think everything else should be basically the exact same.
I haven't messed with either tranny, and I haven't read through they 4T60E how-to in a long time, but if I can find some info, it might at least get you headed in the right direction.-Brad-
Hey Brad, I don't suppose your 440T4 manual have any sections about performance tips do they? The manual we have just mentioned a basic rebuild.
Anyways, for the topic at hand, what other info are you looking for, I have the 440T4 manual here handy and can look up any info you need, perhaps trans numbers that would have your gear upgrade or what not?Brian Edwards
'73 Trans-Am
'79 Suburban
'90 Beretta INDY
'90 Turbo Grand Prix
'04 TSX
'04 TL
If your set up is a 2.8/3.1 and it is mated in a W car then you'll need the drive chain sprokets from a 3.4 tdc 4t60e transmission. that will give you the 3.73 ratio.Lorenzo
I was about to scrap my 60-E b/c I cracked the case.
I pulled the pan for me, but if you need gears, let me know quick.
I know nothing bout the tranny but if you explain how... I can prolly pull it.95 MC Z34 Black
