Flywheel confusion
  • Flywheel confusion
    I'm dazed and confused on 60 deg manual trans flywheels.
    I understand that there are different flywheels for the earlier external balance 2.8L engines , and later neutral balance flywheels for the later 2.8 and 3.1. etc engines. That I understand, but after that I am confused.
    I've never seen the flywheels for either a FWD or a RWD 60 deg V6 in person. Are they the same diameter? Same thickness? Any quick way to tell if a 60 deg manual trans flywheel is for a FWD or a RWD??
    I thought that all the external balance RWD flywheels would be the same, but Advance Auto Parts shows a different p/n for the external balance Camaro flywheel compared to that for an external balance S-10 wheel. Is there really a difference or is Advanced data base jacked?
    When I get into FWD manual trans flywheels I'm more confused. The Advanced Auto parts data base shows the same flywheel (casting number 14018712) used for two different FWD (Cavalier) applications; both a internal balance 2.8L V6 with a 9-1/8" clutch, and a 2.2L four cylinder with an 8-1/2" clutch. Again, seems odd. If true, is the flywheel drilled for two different pressure plates, or do the two different pressure plates have the same bolt pattern??
    Thanks for any help
    Piper106
    RE: Flywheel confusion
    I know the Fiero guys have used both the 9-1/8" clutch, as well as the larger (9-11/16") early S-10 cluch on stock flywheels, so they must have the same pressure plate bolt pattern. I wouldn't be surprised if the same flywheel was used for the 4 cylinder as well with a smaller clutch disc.
    I have a bunch of FWD flywheels, but have never compared them to any RWD ones. What application do you need a flywheel for?
    Marty
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
      the RWD clutch for say a 2.8 fbody does use the same bolt pattern on the pressure plate/flywheel although its alot thicker so wouldnt work in a FWD application. Spec accidently sent me one of those clutches. I "think" the flywheel is thicker too. Because the 3800 RWD manual flywheel is used in Fiero's but they have to machine it down to clear.
      Stephanie
      92 GTZ ~SupermoddedW41GTZ~
