I guess a stock clutch on a 284 can;t take over 300 ft/lbs at the crank, when i;m under boost and the clutch warms up its just starts to slip, so i;m wonder what type of clutch to put in it? i was thinkin towards a dual finction clutch/pressure plate,
Maxed out the stock clutch, at only 8 psi of boost,
RE: Maxed out the stock clutch, at only 8 psi of boost,
I would definately say spec stage 3, I've only heard good things about them. They are a bit pricey ($699), but it won't slip so its worth it. I plan on eventually using one of these in my GP once I get the money for it. I'm gonna use the stock clutch until I get the money, but I'm pretty sure its gonna slip.
Shawn90 Grand Prix STE 3.1 Intercooled Turbo-3100 Hybrid
99 Grand Prix GT
Originally posted by JamesonGT282The stage 3 is not 600. I bought a stage 2 at 299, I think the 3 was 399. I was told my stage 2 will handle over 310lbs of tq, the stage 3 might be overkill anyway.
99 Grand Prix GT
