Does you shift handle attach with a clip in the stem of the handle? If so, the good luck! Every aftermarket shift handle that I could find in 4 years of looking attached with 3 set screws at the base, which only served to gouge the shift rod. They looked like "Ricer Replacements". (AND they never worked right) The only thing my dealer could come up with that attached using the clip was It took junkyard hunting for 4 years to finally find a stock replacement for my electrical taped handle. (tape was the only thing holding my broken shifter together)
