street clutch recomendations
  • #16
    main reason i want to stay away from a puck clutch- they are all sinted iron on both sides. sinted iron is a lot harder on its mating surface than a carbon/kevlar material. the bully stage 2 is sinted iron on the pressure plate side and organic on the flywheel side. when i eventualy have to change the clutch in it, i dont want to have to replace the flywheel becuase its chewed up to much from the sinted iron facing. i also dont think ill be making the power that ill be slipping a stage 2 clutch.
    i have installed stage 3 and 4 clutches that are sinted iron at work in various cars. i find them way to grabby, and most customers regret that they went with such a grabby clutch on the street.
    • #17
      They aren't sintered iron, they're ceramic. here's my spec stage 3 ceramic with lightened option.
      Stephanie
      92 GTZ ~SupermoddedW41GTZ~
      • #18
        Check out 'Competition Clutch' as well, but stay away from the 'Ironman', I have it and it is not a streetable clutch IMHO.
        Z34 red, auto, written of by a red light runner.
        Z34 white, 5 speed, stored in Canada
        Mercedes-Benz C20K, Dubai
        Mercedes-Benz CLK500 AMG, Dubai
        • #19
          wow old post.
          i ended up with a bully stage 2. grabby clutch, not stiffer than stock. its streetable, but kinda tough with a bunch or torque in the rain (read: tire spin). i find you almost need to "pop" it out rather than slide it.
