Hello, I'm new over here on this forum and have a question.
I have 1995 Cutlass supreme 3.1 motor, 4t60e tranny.
Its got about 168k on the odometer,,, motor was recently replaced with another 3.1 with about 90k.
The tranny is starting to give me the blues,,, not shifting when the motor get hot, pulling hard, etc.
I think i might have found a good one from someone but, he's not sure if the plug will need to be switch over or if it will be a direct fit.
The tranny I'm interested in; originally came out of a 91 cutlass 3.1 and was put into a 94 lumina, and I was told that it ran flawless until pulled however, in order to run it in the lumina, the plug had to be converted.
My question is: Will i need to switch my plug over or should i be ok, since it came out of a 91 cutlass with a 3.1?
Any help is appreciated.....
Thanks
Thanks
