W to J tranny swap
  • W to J tranny swap
    this is probably a stupid ? but i didnt see what i was looking for, probably just passed it over, but oh well. Will a 282 (or even the 284) tranny from a W swap into a J?
    RE: W to J tranny swap
    The 282s are the same no matter what body style (there were changes over the years though). The 284 is a much bigger beast and might have some problems squeezing into the J frame.
      thanx. i'll just scratch the 284 off the list of swaps. i seem to suck at swaps i like the easy ones.
        The J-body 282 from certain years is slightly different, as it has the internal slave cylinder. I'm not sure if you could mix and match the hydraulics and make them work.
        Marty
        '99 Z-28 - Weekend Driver
        '84 X-11 - Time and Money Pit
        Quote of the week:
        Originally posted by Aaron
          i'll have to keep that in mind. i looked up the ratios on the site, i kinda like the W's 282 ratios better than the J's. which is better than the isuzu i have right now, its got an icredibly steep 3.91:1 1st and the rest of the gears are about the same as everyone elses, but the fdr is 3.45. 1st is good to get roling, it just revs through there so fast you dont dare spend more than a second in that gear. i like gears that are sort of wide, so i can spend some time winding it out, listening to the motor steadily climb the tach, instead of zing *shift, zing *shift, zing.
            the j-body getrag 282 is best suited for you. the w body is a heavy car, and it needs the different first gear to get it going, were the j-body doesnt.
            from what i have seen, this is the difference in the j-body getrags through the years
            87-89- slave mounted on bracket on trans
            90-92- slave mounted direct on bellhousing
            93-94- internal slave, hall efect pickup speed sensor (not gear driven).
            last time i looked in the books at work, the 93-94 isnt a getrag, i beleive its called a new venture 5tm40. i can double check this tomorow if i get time.
              pretty sure the slave for the 4spd mounts to the housing, but its not something i look at all the time.
                Its all the same transmission. Early on they were called the Getrag Munice, becasue the transaxle used a Getrag-designed gearset from europe that GM stuffed into a case with a FWD GM bellhousing, and was built at GM's Muncie, IN plant. In the early 90's (I think around '93) GM entered into a joint venture with Chrysler to make transmisisons, which was called New Venture Gear. The Muncie plant was part of this JV, so everything made there became a NVG product, even though the design never changed. Its still the same old Getrag, just with a new name.
                Marty
                Quote of the week:
                  so you should be able to swap a 5 speed from a j-body to a w-body?
