First transmission rebuild for me. Im trying to determine if pieces are good or worn and in need of replacement.
All of the hardened parts to the oil pump look good to me except for the aluminum cover. That has significant scaring and I think it should be replaced. To me, the wings looked ok. Is this common wear for the oil pump and can I get that piece, am unable to find at parts store on the web.
All the fine screens in valve body were clean with no metal flakes found.
I may not know some of the correct terminology.
On one of the "fourth clutch plates" a slight ring on pad the steel plate has a chip imbedded in surface causing the ring on other pad. Doesn't appear to be worn just discolored. Looks like a minor flaw from the factory? Not sure if this needs replaced.
The 1-2 and 3-4 servo...the valve stem has slight visual wear but can't feel edges or burr similar to the oil pump wings. Should I replace stem?
