final drive gear machining
  • final drive gear machining
    Okay... I'm going to school to be a machinest and i have come to realise that the skills im learning can be easly appied to cars... so... i am going to be doing the 5-speed swap in the spring and i was wondering if anyone had the complete diagram for the 282 and the 284 because i dont knoe which im going to use yet... and i was wondering also if anyone knew what type of steel the gears and such are... and how many gears i would have to alter to change the final drive... also... i know that i cant just guess at teeth and spacing and diameter... if anyone knows the formulas to come up with the final drive gear specifications... if is fact it is only one gear that has to be changed... or do all 5 gears have to be changed... if anyone would be able to help me out... i would gladly share what i produce...if i can get it to work... and the swap goes smoothly... i dont think i know what im getting myself into... but thats okay... i'll manage. thank you.
    91\' Mazda miata.
    92\' Lumina (sold)
