4T60E vs 4T65E
  • 4T60E vs 4T65E
    Sorry to be posting my ass off tonight, but Frances is visiting Ohio. Question is, What is the diff in these 2 trannies, and what parts are interchangeable? Specifically the differential. Cause there seem to be a lot of performance parts for the 65.
    Hello All
    Can we start a seperate topic for the 4T65E transmission related information?
    I just purchased my 97 Monte Z34, (152K and still running strong) it would be nice for everyone to be able get information on this specfic transmission as to it's durability, strengths and problem areas for future up-grades and or general maintenance.
    Thanks
    John
    PS
    Is there a spell check? I did not see a box to click on for it.
      Originally posted by BMFH
      Hello All
      Thanks
      John
      PS
      SCUSE ME!! This is my thread about comparisons of the two trannies. Go to the trans section and post a new topic.
        4T60e has a vacum mod that controls line pressure where as the 4t65e is fully electronic.. as for internals you have to be carefull what you are swaping in a 4t65e.. The power train control moduals for a 4t65e are sensitive to final drive ratio changes.. If you do change the final drive the computer wont read things correctly and send the transmisson into limp mode (2nd gear only).. A 4T60e you can change the final drive ratio's no problem.. In both transmission the diffs are one of the week points.. Also on the 4t60e's the band likes to break.. if that happens you'll only get fwd movement when you put it into manual low.. A recomendation for the 4t65e is to have a sonex shift kit installed and perform there updates.. the computer for the 4t65e monitors shift timing.. if a shift is slightly to slow 3 times it will send the computer into limp mode... this seems to be a problem considering the shift isn't really slipping that much at all.. the shift kit will help cure this problem..
          What about the other way around? I have seen several companies making lock-up diffs for the 65. Will these work in the 60?
            NO!! The 65-e is slightly larger than the 60-e...
            3800 S3 intercooled turbo...
