What wrong with 2 sensors? Either eliminate one somehows or just put 2 inline. It wont care if one is one each bank or not. Just put then both in the Y pipe. Or if you run duals or something do one on each side.
A liitle different...
Originally posted by betterthanyouWhat wrong with 2 sensors? Either eliminate one somehows or just put 2 inline. It wont care if one is one each bank or not. Just put then both in the Y pipe. Or if you run duals or something do one on each side.This would still be used on a turbo set-up. I'm still trying to remember why I wanted the 3100 PCM over the 3.4 PCM.
