Want your V6 99-05 N-body with a manual transmission? It's actually rather simple to be honest, this is just a guide and NOT a step by step how to
before you even start reading let it be known you WILL need a welder or be nice to a friend with one to make a front mount lol
PART'S LIST:
00-05 N-Body 4cyl 5speed parts(2.2 or 2.4)
-Axles
-Shifter and cables
-Clutch pedal
-Transmission mounts(rear and driver side)
-Clutch master cylinder
-Clutch slave cylinder
-4cyl 5spd subframe(saves you from making a 2nd mount for the driver side)
00-02 J-body parts(2.2 only NOT ecotec)
-Getrag F23 transmission
-Flywheel
-Clutch
-Flywheel and pressure plate bolts
Mounting transmission to your subframe
The J-body F23 has the holes for N-body 5spd mounts for the rear and driver side however the rear mount needs the holes tapped for some bolts pictured below
the N-body bolts are also slightly longer then they need to be, shortened roughly 1/4" and the first 1/2" or so of the bolts have no threads so don't worry about screwing them up while cutting shorter or I guess you can use a washer or 2
For the rear mount I recommend a poly insert meant for a 5spd J-body(95+) slides right in but the bolt for the N-body is slightly thicker so you need to drill the sleeve out slightly. I purchased mine from http://www.energysuspensionparts.com/ part #7515
J-body bushing in N-body mount and sleeve drilled out(15/32" drill bit)
hopefully you have a vice to clamp the sleeve in while boring it out and remember to go SLOW and use some sort of lubricant(wd40, liquid wrench etc)
Front mount needs to be custom made, this is what I'm running
transmission mounted to 4cyl 5spd subframe
Mounting clutch pedal and shifter/cables
I gutted everything except for the dash
Extremely hard to get a picture under the dash of the clutch pedal mounted but this is a picture of all the pedals from a 4cyl/5spd N-body, EVERY N-body has that big chunk of aluminum under the dash and you can kind of see how it mounts
mounted in car
highly recommended removing your PCM/holder to install the clutch pedal, I THINK it's the only way to do it with the dash in the car still...
shifter bolts right in with no modifications and shift cables come out the same hole as your auto shift linkage
clutch master cylinder needs a 1.25" hole drilled in the firewall
those 2 bolts are there from factory once you get your fusebox out of the way, do your best to center the hole and if off slightly don't worry about it as its rather simple to get a die grinder or dremel in there to do some slight trimming also those factory bolts will be to short to bolt the master cylinder on, bring 1 to the parts store and get some 1/4" longer
interior back together for the most part, I left the automatic brake pedal and cut it to fit the 5spd brake pedal rubber
WIRING
99-01 will be this to get the starter going
if you have a 02+ it will still be G&E HOWEVER colors won't match that diagram, G(purple) was my 12volts with key turned and E(purple/white line) goes to the starter relay, can hook those up together to get the starter to crank or hook them up to your clutch pedal to work like a normal 5spd vehicle
02+ starter diagram
Reverse light wires are F/B on C1 connector
MISC
you MAY have to do more wiring if you don't have your PCM tuned already, I found this from the 6spd swap thread
for me I had a tune ready to go and had my PCM flashed with HPT and never did anything else
make sure you buy NEW flywheel/pressure plate bolts, do NOT even attempt to use the automatic bolts as they are a different length
pressure plate #11508687
flywheel #ZX200
obviously don't buy a clutch for a stock 2.2 J-body lol I went with a ebay stage 3 6puck clutch with no issues so far
flywheel can actually come from any FWD 88-02 2.2/2.8/3.1 and if my research is correct same goes for a clutch so that should open up a lot of options but I stuck with the 00-02 J-body one just to play it safe first time around lol 86-87 fylwheels might be the same as well but not 100% on that
when mounting the clutch pedal I found it easier to take the pushrod off the pedal and wait to install that AFTER the pedal itself is installed in the car, insert the rod through the hole in the firewall that you drilled and snap into the clutch pedal
4cyl/5spd subframe is NOT needed but makes it slightly easier, only difference between it and the V6 frame is the mount on the drivers side for the transmission which would be rather easy to make if you can't find a frame
I did my 5spd swap for next to nothing, purchased a 5spd N-body for $350 and sold engine, trans, rims, body for scrap etc and got my $350 back plus at least another $300 to put towards my clutch/flywheel/trans
writing this up rather late so hopefully I didn't miss anything but any questions ask away and if you need more pics very good chance I already have them and never posted lol now lets see more V6 5speed swaps happening!!!
PART'S LIST:
-Axles
-Shifter and cables
-Clutch pedal
-Flywheel
-Clutch
mounted in car
WIRING
Originally posted by timka86
02+ starter diagram
MISC
flywheel #ZX200
