Hey guys, for my current project I need to remove the final drive from the 4T40E trans. I have looked over schematics for the transmission and final drive gear assembly and it looks like I can make it drive straight through by replacing the planetary gear set with a block that just transfers the power. I am assuming no body has had a need to do this before but I figured I would ask just in case.
I also want to install a posi traction differential unit. I know they are made for this transmission I was just curious if the whole trans needs to be disassembled to get to the diff or if there is any way to access it from the tail shaft. Thanks for any advice.
