Car: 97 Lumina, 3.1l, approximately 128k miles
Hello,
I'm still an automatic trans newb., so I need help.
This car's tranny will occasionally drop out of gear or totally disengage and lose power during a WOT/heavy acceleration, usually in the 1st or 2nd gear (not sure exactly which one). Of course, the engine will rev high as a result. I take my foot off the pedal to let the engine reduce RPM, and the trans goes back to normal, it re-engages, and I'm on my way.
It happened again this morning on a hill, and I tried to replicate it at lunch, and it would not repeat the issue.
It will not do this all the time, only when I need it most (lol) at WOT and at random, which leads me to believe the issue is in the valve body or maybe a solenoid or the torque converter, not slippage/wear of the clutch or belts, etc.
I try to drive the car gently, but occasionaly I need to punch it. I'm just wondering if there is an inexpensive fix for this, or if the tranny is on the way out.
Thanks for help.
Hello,
Thanks for help.
