Broke my getrag drag racing last year and finally got a chance to get it on the table this weekend. I thought I broke a shift fork or something and it was locked in 4th gear. But upon removal I can see the input shaft was locked solid - ZERO movement. If it was just stuck in 4th it would move by hand when out of the car.
I split the case and with the extra wiggle room it will shift through all gears (with some serious effort for some) and allows a touch of rotation in the input shaft "out of gear". I have gotten it to spin about 1/4 a few times, but it is not consistent. The next time I can get it to turn like that I'm going to take notes on everything. The forks seem to be fine, there must be something else going on. I'm gonna try to press the input & output shafts out of the case at work to get a better look. It's gotta be something with 4th gear, but 3rd is in the way and I can't see anything until I get them out of the case.
