Cool man, when I installed my HTOB I learned it needed primed with fluid and for some reason it would not work no matter how much I bled the lines. I had to remove it (pull trans) to pump the air out by pumping the HTOB itself and then it worked great. It might just have been how it was for mine cause it felt like it snapped into place or something like that.
I remember 0.1" gap space between the HTOB and pressure plate fingers is desired for wear over time. You can figure the with a straight edge off the bell housing.
Pretty cool how your custom building.
