Okay so let's go ahead and have a little bit of story time here. I used to have a 1995 ford escort lx (the 2 door version) and someone t-bones my car so my insurance company wrote it off and gave me some money for it (yay!). I looked around and found a 1991 Chevy Lumina Z34 with a 5-speed manual transmission in it. I purchased the car right away and drove it home. The next day I was driving it and getting used to the shifting as it has a much shorter shift then the escort does and it kept rattling in second. The transmission started to whine a bit so I went to go and park it and take a look at it but as I went to move the car it made a bang noise and wouldn't go into gear. My friend managed to get it in gear to move it off the road (so it can still drive) and we parked it.
Now I am not 100% sure but I believe the tranny may be gone. There was gear oil all over the road and it had small metal shavings in it. The car can still drive but I don't want to drive it for fear of making it worse, also it makes a horrible noise while it drives (a high pitched whinning). Also, it tries to pop it out of second now and will grind hard if you put it back in second.
If the tranny is gone, what can I use to replace it and what all will I need? I have been researching non-stop since it happened and apparently the Getrag 282 (it has a getrag 284 currently) out of a 5-speed firebird should bolt up exactly the same but then I need new clutch lines or something? Has anyone ever had to swap them out?
I need to stay with 5-speed (because it's all i've ever driven as well as its easier that way) so if I do swap transmissions, what else bolts up? No auto wrecker withing 500 km of me has the 5-speed tranny and the guys from autowrecking.ca said they can't find me one either so I am at a bit of a loss.
Any help is appreciated
(i'm not very mechanically inclined :P)
