I rebuilt the trans ~9k miles (3 years) ago.
It has been having shift problems from 1 to 2 for the past few days. EVERY other gear works perfect. even the down shift from 2 to 1 is perfect....just the upshift is delayed like a MOTHERFUCKER.
here is a quick vid...I was at...maybe...40% throttle at the most....should have shifted at 2500 RPM....then when it did shift at 4k, it rev'd up before going to second. If I get to 15mph or so, throw it into N, then back to drive it will fall in to second or third, whatever is normal for that speed/throttle input, and work fine. If I go WOT, it will bounce off the rev limiter about 15 times before it will shift.
It did this a few times before I left for Toledo this past weekend, now it's every time.
Leander helped me rebuild this ~9K miles ago....I was really hoping for a trouble free trans for a long time.
any ideas?
any ideas?
