im looking to do a manual swap in my 96 monte, it has a 3.1 and my 4t60e just hit 125k miles and im wanting to do a manual swap.... any ideas????
automatic to manual in 96 monte carlo
96 Monte Carlo *Eleanor* 3.1 with colt cam, 8mm msd wires, bosch x4 platinum plugs, CAI with a k&n 3.5 clamp on filter, 2.5" exhaust, 2.5" glass-pack single 2.5" tip, ebc brake rotors, green neons, 8k xenons, fog lamps, 2 12" mtx jackhammers 800watts each with slotted box, and 1200watts sony explode competition amp.Tags: None
bump..... anybody????96 Monte Carlo *Eleanor* 3.1 with colt cam, 8mm msd wires, bosch x4 platinum plugs, CAI with a k&n 3.5 clamp on filter, 2.5" exhaust, 2.5" glass-pack single 2.5" tip, ebc brake rotors, green neons, 8k xenons, fog lamps, 2 12" mtx jackhammers 800watts each with slotted box, and 1200watts sony explode competition amp.
Wouldn't bother doing it with a 3.1. Truth fully I wouldn't buy a Monte with a 3.1, Drum brakes, no duel climate control, possibly no abs, steering column shifter.
Originally posted by Dave96z34 View PostWouldn't bother doing it with a 3.1. Truth fully I wouldn't buy a Monte with a 3.1, Drum brakes, no duel climate control, possibly no abs, steering column shifter.96 Monte Carlo *Eleanor* 3.1 with colt cam, 8mm msd wires, bosch x4 platinum plugs, CAI with a k&n 3.5 clamp on filter, 2.5" exhaust, 2.5" glass-pack single 2.5" tip, ebc brake rotors, green neons, 8k xenons, fog lamps, 2 12" mtx jackhammers 800watts each with slotted box, and 1200watts sony explode competition amp.
Its alot of time and money for the swap unless you already own a DHP tuner and are experienced I wouldn't even bother.
Only 2 mods cam and exhaust the rest are all not worth much and the sound equipment is just added weight. Monte's are heavy anoph already.
A getrag 282 will bolt where a 4t60e was. The mounts are getting hard to find for a w-body but possible.
You will also need to swap the axles to fit the trans to hubs.
Mounting the clutch pedal and master will be tricky but possible. My 96GP is a w-body and I swapped in a 5-speed. It is entirely possible.
Best way is to find another w-body car with a 5-speed for the parts car. Lots of little things needed can be sourced from the parts car. Like the trans mount. The brake booster might be too big if you got the large one. But having a parts car will solve that too, just yank the booster used. I didn't have a parts car and it took me a year to source different parts needed, fabricate some things, build a hydraulic clutch with different parts from here/there. Can be done much faster though, I like to take my time and do it right the first time.....and even then I still goofed a few things up, had to fix them.Last edited by TGP37; 03-10-2012, 10:26 AM.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
