Hi - first timer here.
1991 Buick Riviera with 120K miles
Problem: With the engine cold and driving off in the mornings, the car simply won't accelerate worth a darn when I give it gas. It doesn't stumble or jerk or rev high (miss a gear or slip), it will just barely go. It also makes a distinctive whine noise while the issue is happening.
Once the car reaches full operating temperature the car accelerates and cruises just fine. No check engine light, trans filter/fluid changed 20k miles ago, fuel filter changed - spark plugs look good. Trans fluid color looks good and is full.
I am thinking that this a transmission issue vs. an engine issue...but of course I am no pro. Just looking for some advice
thanks Rob
thanks Rob
