This is a dumb idea from the start but im fixed
  • This is a dumb idea from the start but im fixed
    I am wanting to know exactly how hard and whether it worth the trouble to swap a new axle in to make my cavy a RWD vehicle and put a high performance v6 or v8 depending on the cost between each
    Though i just wanted an idea from some other people whether for the money i could do more to my current setup or drop it all and start from scratch:dead
    alot cheaper to just buy a RWD to begin with. but it's your money.
      well i really like my cavy but ive got the opportunity to get another third gen camaro so im just looking at my options i didnt see any posts like this anywhere so i thought i would give it a shot
      but the camaro come with a 400 small block so idk whether or not to go for it
        plus the camaro is already RWD correct?
          yes but he wont sell me just the body but i like the setup on my cavy so im torn on what to do cuz id put prob the same amount of money into either one
            It can be done, but it's going to take a big chunk of money and some one who knows what they are doing when it comes to cutting into the structure of your car and welding stuff to it. You don't want to end up with a RWD Cavi to have it fold up under you when you go over the first set of rail road tracks.
              Well if its even possible since its already there i want to get an AWD tranny because i dont want to have to pull it all out if it can be used
              But idk whether or not if it would be worth the money
              Though even the possibility to put a import engine if i have to for it to be AWD whatever is up for a option cuz i dont kno what is actually capable
                  Thank you for the link i knew it was possible but my main concern is that whatever i do im going to driving this car as my daily
                  Though i dont mind having to put gas into it but whether it would be even safe to do it
                  As i thought my tank is in the way but i can relocate it to the spare tire well
                  Also to include if i decide to out a v8 into it the engine isnt going to be easy going i will have the largest v8 it can hold which does concern me cuz the car would be the death of me im sure
                    My wifes old 95 T-bird had a tank that the driveshaft went through, if you are looking to do mostly junkyard parts/on the cheap. It wasn't like there was a tube through the tank, it was more like a flattened "U" shape, and there was a hose that went from the top of one side to the top of the other so it could purge air from one side to the other as you filled it up or cornered hard.
                      I discussed this thoroughly on v6Z24 with bondo07,
