Is there anyway I could use my 1990 Quad 4 GTZ HO tranny and just swap belhousings with a V6 tranny and use it? Because Ive got a perfectly good transmission, and it shifted very well before the motor blew. I know the gear ratios are very similiar, so Im thinking that this could work.
Quad 4 -> v6 tranny
yup. thats all you need to do really. just swap front case halves. i'd check the proper shim in behind the diff bearing.
in a 90 GTZ the ratio s are the same if its a regular Getrag trans such as a J/L body one.Colin
Originally posted by v6h.o.yup. thats all you need to do really. just swap front case halves. i'd check the proper shim in behind the diff bearing.
Yeah its a normal tranny, this should make my 3400 5 speed swap a bit cheaper.
Should compliment my bilstiens, eibachs and poly upgrades that I'm currently doing nicely.
