Howdy ! Forum newbie here ! JUST got a problem with the trans. I've got a 3.1 V6. Was drving along minding my own business last night, stopped in and got some gas ... must be gold lined or something theses days .... then when pulled out of the station the trans wouldn't hardly shift out of first. Never had slipping or anything.... until now. If I drive as normal it will wind way up then finally shiftafter several seconds, or if I take off pretty fast then back off it will slow down and shift. All other gears seem to shift fine after that. I did try to manually shift it from first, and no difference, also tried to manually start off in second and it actually did the same thing. Any clues from the guru's here?
