Where is a good place to get some of this stuff. I have two cars 4t45 and nthe 4t60e some of these tools are universal some may not. I just dont see much of it at the auto parts store is some of it only at the dealer. thanks for your help
tranny tools?
What tools are you looking for specifically? I built my 4t60e without any of the specialty tools.
like a forward clutch spring compress gm# j-23327-1, maybe 1st -2nd and reverse band apply pin gauge gm #j-33382 maybe just enough for a basic overhaul. If you got by without any of this maybe i can to. did you just improvise . i was just kinda going by my book haynes is not the best i guessLast edited by BLADE; 11-08-2010, 09:27 PM.
Yeah you can get by without a compressor... As noted the springs do have pressure on them but not that much. JUST get a good set of circle clip pliers that work in all sorts of different ways. I want to say that's the only necessary tool really.
As noted I did a full overhaul and performance rebuild with standard tools. I made up my own end play loading tool to check install height of the entire assy and such. Its not hard to improvise on most of this, and for a standard refresh if you don't see any major wear on the thrust washers and such then shimming the whole assy typically isn't necessary. I mixed and matched parts from other transmissions so I had to be sure my clearance was correct.
Oh yeah, hose clams work REALLY well as teflon ring resizers
Hell I made my own transmission holder out of my spare engine stand.
ATSG service book FTW! Its a must when you do one of these. I pulled an old busted one apart to learn it but without the book I wouldn't have been able to get everything right.
And yeah that stand works great, most of the build time you need the trans in the upright position so you can stack parts, but since I do not have one tool to hold together the whole input assy I need to drop it sideways and slide that in then twist it back upright again. Works like a charm, I used to do that on two saw horses.... this is a far better method... LOL.Last edited by 3400-95-Modified; 11-10-2010, 02:15 PM.
With your idea for the stand I'm really looking into getting a junk tranny now to rebuild it. ATSG does not have a book for the 4T45e but does have a book for the 4T40e. (They say 95-96 models) http://atsg.com/cart/products/4T40E-19-5.html
Would it be safe you think to use this book for a 4T45e?
According to Transmission Parts USA they are the same book, or at least he 40e book covers the 45e one.
ATSG transmission repair manual,4T40E transmission repair manuals,transmission rebuild kits with pistons
here is a breakdown and OEM part numbers for your trans
Also From a J-body site.
Heres the difference when the MN4 and MN5 are compared.
Hydra-Matic 4T40-E/4T45-E Transaxle (MN4/MN5) What's New or Changed View Photo Top of Page
Type: four speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with electronically controlled torque converter clutch
Engine range: 1.5L - 3.1L (MN4)
3.0L - 3.4L (MN5)
Maximum engine torque: 190 lb-ft (260 Nm) (MN4)
205 lb-ft (278 Nm) (MN5)
Maximum gearbox torque: 325 lb-ft (440 Nm) (MN4)
325 lb-ft (440 Nm) (MN5)
Gear ratios:
First: 2.95
Second: 1.62
Third: 1.00
Fourth: 0.68
Reverse: 2.14
Maximum shift speed: 6500 rpm (MN4)
5800 rpm (MN5)
Maximum validated gross vehicle weight: 1990 kg (4347 lb)
7-position quadrant: P, R, N, OD, 3, 2, 1
5-position quadrant: P, R, N, D, D3 (MN5, Malibu)
Case material: die cast aluminum
Shift pattern: (2) two-way on/off solenoids
Shift quality: variable bleed solenoid
Torque converter clutch: pulse width modulated solenoid control
Converter size: 245mm (reference) (diameter of torque converter turbine)
Fluid type: DEXRON III
Transmission weight: dry: 74.7 kg (164 lb)
wet: 85.1 kg (187.6 lb)
Fluid capacity (approximate): bottom pan removal: 7L (7.4 qt)
Complete overhaul: 10L (10.6 qt)
dry: 12.5L (13.2 qt)
Pressure taps available: line pressure
Transfer design: two-axis design, link chain assembly
Assembly sites: Windsor, Ontario
Applications: Chevrolet Cavalier (MN4)
Chevrolet Malibu (P90)(MN5)
Chevrolet Malibu (GMX 380)(MN5)
Pontiac Sunfire (MN4)
Pontiac Grand Am (MN4/MN5)
Oldsmobile Alero (MN4/MN5)
Saturn L-Series (MN4/MN5)Last edited by 3400-95-Modified; 11-11-2010, 01:58 PM.
thanks for the pics great idea.I am going to look into a astg service book. I guess i wont worrey about the rest thanks for the replies. for now back over to the repair forum LIM or head gasket started leaking again only 35000 mi on these new ones wish i would of known 3 weeks ago when the moter and tranny was all out oh well gotta roll with the punches
Transmissions are fun... lol
I gotta pull mine this year and get the LSD freshened... other than that I don't have much else to do, maybe I'll open her up to see how everything looks after running my 12's...
transmissions are fun to build ive done 5 they are alot easier than you think. another good company to look at while you got it apart is sommax they have lots of little fixes and stuff for the valve body. also i forget the name atm but there is a company for gm that sells different coefficent of friction clutch discs and bands for faster gear shifts
Looking at a core tomorrow and found a supplier for Raybestos Blue Clutch plates for only 150 bucks for the whole module...cheapest I've ever found.
Would you all recommend replacing steels? I know that you determine if they are worth keeping when you look at em, but for 40 bucks would you say its worth it just to replace them?
