fill it as much as practical.
Need help 4t60e
Originally posted by BLADE View Postwell I went ahead and ordered a FD9B[2095stall] torque converter from bulk part today 203.00 with shipping. Im glad I had all you guys help on this this was not a part that is readily advalible at most auto part stores I would tell them I needed a torque converter and some would still ask if it was a standard or automatic tranny. Bulk part seemed to be a good place to get some of this tranny stuff.
gpse3400 what do you mean when rotating the stator splines try not to rotate it against the converter??
I think you mean not to push down to hard while rotating the stator spline in the converter. I have never messed with one of these so not real shure what to look for. I already ordered a new one but would love to learn a good way to check these for in the future.Lorenzo
well im still waiting for my torque conveter i hate waiting i need to get this going. Just been throwing a few parts at the moter while its out Timing gears ,chain,gaskets,balljoints,sway bar links, brakes and rotors not to metion a bunch just before all of this.Just hope it runs for awhile after all this
When I turn the old torque converter second spline in its smooth for part of a turn and rough for part of a turn. Sometimes it will spin both ways with little resistance clockwise or counterclockwise.And somtimes the stator will resist a counterclockwise motion but not all the time. The book that I had said to drain all fluid before doing these tests to the torque convereter. I did not drain all the fluild only about a quart or so.{Its in there duringnormal operation I didnt want to change that] There was also a endplay check which i did not do at this point i figured it was bad anyway.
well i got the new one today shure did spin smoother than the stock one. I have been trying to fill it i have 1 quart in it already. I think that i read somewhere that the torque converter holds 4 quarts so i am going to try to get at least 2 quarts in it maybe more that should fill it halfway if i have the numbers right. there was a little fluid in it like they tested it before they sent it out. hopefuly i can get it back together this weekend.hope this torque converter solves my problem
ya I got a quart and a half I figured that would lube it a little anyway. It was taking awhile to seep in the torque converter. Well anyway I got the moter and trans put back in the car today about 45 min just to drop it in with the old lady it went in good we didnt even get in a fight hahaha. Im shure some of you can relate to that. So hopefully tomorrow i can get the rest of the stuff hookedup and start it up if all goes well. I might just have it back on the road monday.kinda worried about bleeding the brakes hope I dont have a hard time getting the air out Im going to check those threads out thanks to all of you that have helped me this tranny stuff
Well, since you were capable enough to tackle this job, bleeding the brakes will be cake. Especially with two people. My wife has helped me bleed brakes many times.-60v6's 2nd Jon M.
almost got it going a little behind got it running just have to bleed the brakes and take it for a ride. Cant wait to drive it and see the diffrence in the two diffrent stall speeds. It did start almost right back up about 10 seconds of crank time not to bad and runs smooth glad i did all that work timming set ect no leaks either all new gaskets hope it will go another 50000mi befor another tear down these berrettas seam to run good for a commuter car
Originally posted by robertisaar View Posttechnically, berettas were "sport compact" before it meant rice.
But yeah your right... The Commuter version is the Corsica... The Beretta was at one time the hopefull to replace the camaro since they thought FWD woudl rule everything... Hence the reason a 96 Z26 cost more than a Camaro did at the time.
new I was dreading the brakes went got a vac pump went to start bleeding and snap off the bleeder screw on the back . didnt do the other side letting it soak in wd-40 but its going to break to. So I guess ill get new cylinders tommorro. Just had one of those bad feeling about these brakes
Any bleeders on a car that is over 8yrs old are almost sure to be rusted solid... also depends on your location. BUT all and all the cylinders are rather cheap, so as long as you can get the line out of the cylinder you'll be golden.
Now would probably be a good time for me to mention I tend to put a small amount of anti-seize on bleeder threads to prevent this sort of thing from happening in the future. Then again, I remember being told you are supposed to change your brake fluid ever few years which makes sense since it likes to absorb water.-60v6's 2nd Jon M.
ya the bleeder broke then the solid brake line broke in the cylinder as well. so I got to bend some brake line up and then bleed it out wasnt to bad only one back one the other side cylinder was replaced not to long ago. Anyway got it runnig again it goes great alot of parts went on it. And the torque converter was the fix for the tranny no more shudder or slight grinding sound when in gear stopped. all good for now. I would like to say thanks to all of you who helped me along the way I saved a ton of $$$ on these repairs it wouldnt have been worth it to pay a shop to do all of this. thanks for your time everyone
