I've never tested a torque converter that way... but some shops yes will re-use it unless its part of the rebuild, you would see the extra charge on your bill since they aren't free.
What position was the TC in when you tested it?
Did you have any material in the pan of the transmission either? Depending on what parts they used you could have a low roller sprag going out which would cause some noises and quite possibly some shuddering when accelerating. Unfortunately that requires you to did into the trans to find that.
There is no B&M shift kit for our cars, OR any real performance shift kit for it. The only one out there is a shift CORRECTION kit. It simply changes some things to prevent common issues/failures. It will help firm up the shifts a little, but as noted the only way to do that is to shim the accumulators.
