will the clutch hydraulics and shifter off of a 4 speed manual from a fiero work on the F40?
F40 transaxle
its all a question of cable throw. you wouldnt know till you hooked it up. it would be easy to mount the G6 shifter assembally
no it won't work. the F40 uses an internal style slave/throwout assembly. you'd be better off swapping to the G6 master cylinder and using the stock F40 hydraulic setup if you're going that route.
Cammed 3400 --> 224whp 210wtq
Cammed 3500 --> ???
1 of 5 3500 J-Bodies
/\ he's right, how ever i think the shifter assemablly does work from a 03+ cavi, but of course you will have to modify the **** out of it.
So far my solution to the F40 needs have been solved towards the end of my thread. The G6 flywheel should be fine up to about 300 lb/ft but above that it may start to slip because it is torque limited. I have a G6 flywheel and pressure plate for sale for anyone interested since I don't need it anymore, both parts are in good condition.
You should be able to find valuable info here
Originally posted by RedBird View Postno it won't work. the F40 uses an internal style slave/throwout assembly. you'd be better off swapping to the G6 master cylinder and using the stock F40 hydraulic setup if you're going that route.
Disregard, I see this is for a wrong wheel drive car (FWD), however the process should be similar except the Fiero shifter would have the cables exiting aft instead of forward so it would not work.Last edited by Guest; 11-26-2010, 10:08 AM.
