Hi guys thanks in advance for any help. I have a 2004 olds alero 3.4l with an automatic transmission. what trans do i have the 4t40e or the 4t45e I looked at the tag on the transmission and couldnt get a straight forward answer is there some way to decode the tag. on my 95 berretta its imprinted on the bottom of the pan 4t60e no problem. But the alero is not like that. And am I ok with dextron III ATF or is it ok to put synthetic oil in these. Im open to all options. My haynes manual says dextron III.
what tranny do i have
i counted 14 bolts on a trans pan gasket on a 4T40.
just look at your RPO codes...
MN4 is the 4T40
MN5 is the 4T45
in 2001 at least, a 3400 alero has a 4T45Last edited by robertisaar; 08-21-2010, 02:29 PM.
