does any one know of any mounts that will bolt a 95 olds 4t60e in to a cavalier my cavalier is a 02 and had a ecotec with 4t60e but the mount is diffrent just cheekin to see if anyone knew of a mount that will work befor i pull out the welder and make something work
transmission mount is diffrent need help
well after i looked at the two mounts and mest with the car and the trans a little this is what i came up with what do you all thank
stock jbody mount
moded w body mount trimed off were it bolted to sub frame and welded the center part of jbody mount to it
and now my w-j mod trans mount all done
