you may want to check out sonnax....they make correction kits for the valvebody that correct the problems that cause clutch wear(yea...found my coulprit). www.sonnax.com
...here is the direct link to the parts im talking about....just search for 3t40 on the left side...and the results will pop up on the right...
When looking for parts or kits for your trans....Make sure you look at the 2nd gen 125-c (85 and up). Pre 85 units have diffrent parts.
...some may not know...but they also have a narrow chain drive (AKA...weak suck).
